Hey guys, I drained and filled my through the air bleed nozzle. Is this an effective way to clean out ALL of the fluid that in the piping radiator and engine?
I first used hooked up a water hose to my resevoir and another line to my air bleed, and I got 2 buckets of old pink fluid. ( i know i shouldn't be using tap water, but it was an effective to have the pressure push out all the old stuff back )
Second, i used pre mixed toyota coolant, using a hand pump to push fluid into the system and out of the air bleed. The system used almost 7.5 Liters of coolant.
Question - was this method safe and did it flush everything out of the system?
