1 - 9 of 9 Posts
1999 Solara SLE, V6, 352,000 miles
The connectors to the forward ignition coils had seen better days. They no longer snapped on securely, and when replacing them, one actually crumbled. I found a good replacement, at a lower cost than other options, saved a few bucks. They come pre-wired, ready to install.
Part number is ACDELCO PT2045, or 88988587
Discussion Starter #2
Factory left, replacement right. only downside of these, they are not color coded.
300491
They do come with quick crimp connectors, I prefer linemans splice, solder and marine grade heat shrink
300492
300493
300494
Discussion Starter #6
tried to reuse old grey plastic protective covers, but too much, they are in the way, instead used cloth protective tape, same stuff used in BMW's
300495
Discussion Starter #7 (Edited)
Good to go, now don't have to worry about daughter having a coil connector pop-off in the middle of no-where or on the side of the freeway.
300497
Super Moderator
Nice. Added to the sticky.
Connectors on the 2002 V6 Accord I just swapped heads on also snapped off.
Your fix is more permanent, I just tie wrapped them on with a black nylon wire ties.
1 - 9 of 9 Posts
