The order you do what in?
Valves and TC, or the order you adjust the valves?
For the 1st, no, but I'd do the TC 1st
For the 2nd, yes.
The order you do what in?... Does it even matter which order I do them in, just wanted some claification thanks in advance for any responses![]()
Depends....not if he needs his head worked on. If you have head work done then I would adjust your valves twice. I would adjust them once you have everything back together...then adjust them after you warm it back up. That is how I did it. I would rather KNOW that I took the time to pay attention to the valves twice then carelessly over tighten a valve and burn one.The valves should be adjusted hot, so before you start the tear down run the engine to operating temp and yank the cover and adjust the valves. then instead of putting it back together just keep going, that way you won't have to put the valve cover on and take it back of after it is warmed up.
2WD trucks don't have front axles.....Doesn't the manual say to remove the front axle? I didn't remove mine for the reason that I didn't want to remove suspension parts. I hope that is not the case though with yours. I hope you can slide it out???
