My 2 is currenlty apart in my garage right now and i am replaceing the valve cover and the gasket, i decided to go with the most obious place (occording the the jan. 2006 edition of Sport compact car) that is where they said to check. but more to the point.... its said in the write up that it might not be the valve cover at all it said that for some reason toyotas decided to use phillips head type valve cover fasteners, which ment that they never stayed tight and this could cause leaks. they said you could get replacement hex set of fasteners from twos-r-us but when i checked the site i found nothing.... Any suggestions??? thanks!
