1 - 2 of 2 Posts
Good Morning Gemtlemen,
I have a problem that I’d like to see if anyone else has experienced this.
I have an 04 prerunner,2.7L and I’m trying to remove the valve cover.Simple project,you’d think.I cannot lift it completely off because the harness bracket in the back is in the way.I’ve removed the clips that hold it in place and I can move the bracket around but there is no way the valve cover clears the bracket,not even close.
I even watched a video of a guy removing his and he removed the clips and when he was ready to remove his valve cover he was able to do so.His is a 98,mine is an 04 but they look identical to me.Did they change the hard plastic cover on the wiring harness between those years or something? It’s impossible to remove my valve cover because the harness doesn’t have enough room to get it out of the way.
At a loss....
1998 T100 SR5 2WD
I take it that you have the 3rzfe engine? Could you snap some piccies of the wiring harness and what the issues you are having and post them? Thanks! ;)
1 - 2 of 2 Posts
