The valve cover gasket will cause oil leaks. The job should be about 1 hour of labor plus the cost of the gasket. The $90 seems very reasonable for this job. It will have nothing to do with your problem of heating up.
Mike
Mike
alright then what do I need?You can do the valve cover gasket yourself for about $20. And it is VERY easy to do on the 4cyl 5F-SE engine.
i would recommend get the valve cover gasket and 4 gromets for the spark plug stem. last time i walked into a local toyota dealer, cost roughly about $30 after tax for the parts, and some silcone at auto store or walmart.alright then what do I need?
It's pretty easy. I did mine last week when I noticed a leak while changing my plugs. I used silicone because it was not planned and I did not have a new gasket at the time.alright then what do I need?
