Valvoline Maxlife Synth.
1188 Views 2 Replies 3 Participants Last post by  just2asian
I was thinking of putting Valvoline Maxlife in my 92 XLE. It has 175k on it and leaks a little oil, and I have been told that the Maxlife will condition seals. However I have also been told that going to synthetics after running non-synthetics will make your seals leak more. Does anyone have any experience here?
1 - 3 of 3 Posts
see, it's actually very confusing haha.
i even used to work at vavloline, and i learned the same thing. then i switched to max-syn, and i was already leaking aswell. I switched to syn. and it still leaked, but after several months, i am actually noticeing LESS leaking, which means im not leaking as much/fast.
i still change it every 3K even though it's syn. but the good thing is that everytime you get low, you can go right back to valvoline and get it topped off for FREE, so as long as you keep an eye on it, then you can stay topped off everytime you get low. so that's what i do.
when i switched i had around 180K miles on my cam I4
but you have the V6, so it might be a different story
Yes synthetics are thinner than dino-oil, but syn also have conditioners and additives to that swell gaskets a little so that may be why you oil leaking problem has gotten better. I have switched to valvoline maxlife synthetic right before my car turned over to 100,00. The car feels like that it likes the syn better than the dino-oil. So I say, go for it!
1 - 3 of 3 Posts
