I just got done doing the water pump and timing belt in my 1999 Toyota Camry CE four cylinder, at which time I also replaced my pulley belts. Prior to doing this job I had noticed I was getting a squeal once in a while, but nothing too bad that didn't go away once I started driving.
After completing the job I see two things are happening. First is whenever I turn my wheel, even the slightest bit, I'm getting an awful loud squeal, and at the same time my power steering pump is actually halting during the squeal.
The pulley belt isn't too tight, nor is it too loose, the fluid is full, and I don't see any leaks. Oddly enough, or coincidentally you might say, I did find a big crack in my air intake which had to have been there for a long time, so I took it off since I'll be replacing it later with a new one. I'm not sure if the squeal, which has gotten exponentially worse since the belt was replaced, would have really been this bad before I took the air intake off....
Unfortunately I did not have time to test if there was any relationship between the air intake being off and the power steering squealing like crazy, but I know it wasn't squealing this bad before I replaced the belt, nowhere even near this bad. Could the air intake being completely off have something to do with the power steering pump acting up?
