1 - 4 of 4 Posts
hi i,m new to this forum, i,m looking for some help . i have a 96 camry that vibrates at idle, i changed and double checked timing belt, chked distributor, plugs, wires, iac valve,tps, no vacuum leaks, no fault codes. followed throubleshooting chart in FSM. suspect MAP sensor but not sure i.m interpeting readings on scanner correctly, it cost $325 so want to make sure b4 purchase. if anyone can help would be very grateful, thanks :confused:
Please search as this same question is posted about once a week. If it is a 2.2L, learn to live with it. OEM motor mounts seem to help the most, but you will have a little [email protected] idle...until the end of time.
Bear
Bear95 is correct. Some vibration at idle with the generation 3 (92-96) 5SFE engine is normal. I am the original owner of a 94 5SFE engine and my car has been vibrating at idle since it was new. Cleaning the throttle body may help a bit, but the vibration is probably normal.
Mike
1 - 4 of 4 Posts
