1 - 3 of 3 Posts
Miata
I have a 2006 Limited 2wd 4runner with 191k bone stock.
In the last few days it has come up with an issue I cant pinpoint. I can feel a vibration when driving only when on gas, accelerating or constant rate of speed. Let off gas it goes away. Put it in neutral is goes away. Its getting worse.
I'm going to pull it apart today but I dont know where to start looking. I'm guessing driveshaft or rear? Any common issues here?
Thank You
1998 T100 SR5 2WD
I would suspect the driveshaft in particular the U-joints. A driveshaft shop near you should be able to git it done if that is yer issue. ;)
Rockin' 'Rolla
98 Civic, 04 4Runner
I have the same issue on my 04 SR5. I greased the ujoints, changed the diff and transfer case fluid and it did not go away. I've heard people saying if you change the trans fluid it will go away.
1 - 3 of 3 Posts
