I have a 2005 Tacoma DCSB V6 4x4 SR5 with leaf spring TSB and have had virtually no problems.
I have an LSD rear. Nov 12th, 2008 with 21,046 miles, I had the fluid changed by the dealer because it would squeal the tires when turning from a stop and accelerating. This was in drive. They replaced the slip diff oil and 1 LSD add. That fixed the problem.
I had Firestone Destination A/T tires put on last in Nov 09 to replace the crappy Dunlops.<<<I don't know if this means anything.
I have noticed, just in the last couple of weeks, when I am leaving work, and I back up turning out of my parking spot, the whole truck starts vibrating slightly. It feels like the source is from the rear. Once the truck is warm, this behavior stops. I can only duplicate it when leaving work as stated above, after it has been sitting there for 9 hours. It is very noticeable. There is a stop sign right after I leave the parking lot and I have to turn from a stop. I don't notice it then. Only when backing up and turning out of my parking spot at work from a cold start.
The parking lot is not in the best shape, it does have slight cracks, etc., but I have never noticed this behavior until recently. I have even parked in completely different spots at work....same effect. I thought it may be my rear brakes, but today I let off my brakes and it persisted. I have been watching for it, and today it was most noticeable. When I leave my home in the morning and back out, I don't notice it.
I only have about 32,000 miles on it (31,111 to be exact).
What could be wrong?
