1 - 11 of 11 Posts
Ok so here goes... 03 Toyota Matrix 323k miles Xr
So driving to get to the highway everything is fine normal stoping for traffic lights, get on the highway and start to feel like my front passengerside wheel is about to fall off. It vibrates when i get to about 60 then it will go away. It feels like a mix between worped rotors and wheel bearing or tie rod. Pads and rotors were replaced in the spring im wondering if it might be the brake line colapsing and it gets worse if im stuck in traffic
Please any help would be greatly appreciated
· 19 Corolla HB SE 6-spd
It could be an imbalanced tire/wheel assembly, damaged tire and/or wheel, free-play in inner or outer tie-rod end, ball joint, or wheel bearing. Ripped or separated control arm rear bushing, blown strut...
· ALSO AVAILABLE IN SOBER
· Administrator
マズダスピード3
Not sure why, but the 1zz is supposedly long lasting. According to the sales pitch, you don't need to tune up for the first 100k. Glad to know someone can go far with a 1zz. Being that the first 1zz's from West Virgina had a tendency to last half that.
· Super Moderator
2005 Corolla CE
That's genuinely funny. I buy cars for a living. I've seen a LOT of dead Vibe and Matrix clunkers.
I'm not saying they are bad cars... but not many ever see 300K. You'll have to sell that somewhere else.
Your view, like mine and invader's ultimately, is subjective. I don't believe anyone was trying to "sell" anything to anyone.
We have the above linked thread dedicated to the "problem" of clusters that max out at 299,999 Miles and KM. Owners have to replace clusters when that happens which either resets mileage to zero or they get a used cluster with lower mileage. This means that unless it's reported or the cluster is locked, you can't even know if the car truly has over 300K. There are sure to be plenty of "120K" examples that actually have well over 300K with an unreported cluster replacement.
There are a LOT of owners here that have well over 300K on these cars. You can read the maxed out mileage thread or just the reported mileage threads to see for yourself. This would obviously not include members who simply didn't report their mileage. Clunkers are usually that way because of poor maintenance by the previous owner. A very poorly maintained Toyota will likely have less longevity than a meticulously maintained Chrysler.
There is nothing from a build standpoint that should prevent high mileage. The vast majority of issues with these cars are for minor issues. Like with most cars, simply maintaining the fluids will likely get you past that mileage.
Reactions: invader
Define LOT.
This forum probably represents .01% of Toyota owners... and the people here are the fans. A thread proclaiming the virtues of any car in a forum of any kind is virtually meaningless statistically.
I've been in the auto biz for 30 plus years and seen millions of cars go through auctions and dealers. 300K simply does not represent ANY group of vehicles on a regular basis.
I am sure there are a few. I recently saw a Chevy Malibu with over 250K at auction that was still running. That was a really hard one to believe. Heaven only knows what they had to replace to get there.
I still find in nearly impossible to believe anybody could sit in the same seat and drive the same car for 300K miles. Sheer insanity.
· Super Moderator
2005 Corolla CE
Define LOT.
Define many. I already stated it's a subjective discussion.
How many cars are built? Of those, as a percentage, how many will go to 300K? How many 2003-2008 Corolla, Matrix and Pontiac Vibe models were built? As a percentage, how many will go to 300K? Nobody here has answers to those questions.
If you even read the threads, they were even meant to display "virtues" of any kind. Rather one is for owners to post/report mileage and the other was to discuss the cluster maxing issue.
As for that fact that most cars, regardless of brand, model, or year, will not go 300K. That is likely true. However YOU asked HOW a Matrix (a 2003 no less which is the worst model for issues), went 323K as if it's an impossible task. You then related how in your experience you have seen many bad examples and without any explanation suggested no reasons WHY 300K is not achievable and suggested you were being sold something. When given a thread of examples of these cars going over 300K with actual documented examples and an explanation of the means to achieve that goal (good maintenance), your reply makes new baseless insinuations to support a counter point to an argument NOBODY MADE.
Why could someone go 300K in a vehicle? Maybe they are in sales or have a long work commute. Maybe it's 6 people who owned it at different times. Maybe someone just likes it that much. People have widely varying reasons for why they do anything. My Sequoia has 215K and has needed only minor maintenance and repairs (door handle, bulbs, etc.). Even with the widely report issues of Air Injection system issues, it has never had a reported fault in nearly 12 years and the above listed mileage. Vehicles sold through dealerships are also not representative of all vehicles on the road. There is less incentive to trade a 300K mile Matrix vs. selling it privately.
Your initial post added nothing of value to the discussion and was probably meant as a joke. I really don't see the point you were attempting to make by continuing forward. The OP is trying to get help on an issue relevant to their vehicle. If your only intent was to reply in an attempt to poke fun over owners and enthusiasts on this particular forum, shame on you. That won't be tolerated and you should know that better than most. If not, well I think we can agree that OP get an answer to their questions.
OP like others stated, your issue is likely wheel balance caused by imbalance, a bent wheel, or defective tire. Have it looked at by a tire shop.
Reactions: ws76133 and invader
1 - 11 of 11 Posts
