1 - 3 of 3 Posts
Banned
2008 Toyota Camry Base / CE
Hi all,
I'm just listing my preferred fluids and filters for anyone's reference and as a note for myself:
Vehicle:
2008 Toyota Camry Base/CE
2AZ-FE Engine
U250E Transmission
Fluids:
Washer Fluid:RainX 2 in 1 All Season
Oil:Mobil 1 0W-30 Advanced Fuel Economy
Coolant:Toyota Super Long Life
Automatic Transmission Fluid:Toyota Automatic Transmission Fluid World Standard
Brake Fluid:Wagner DOT 5.1
Power Steering Fluid:Mobil 1 Synthetic ATF
Filters:
Oil Filter: Mobil 1 M1-103A Extended Performance
Air Filter:K&N RU-4990
Air FIlter:AEM 21-203D-XK
Cabin Air Filter:WIX 24483XP
Automatic Transmission Filter/Strainer:Toyota 35330-08010
Automatic Transmission Filter/Strainer Seal:Toyota 90080-30077
Automatic Transmission Pan Gasket:Toyota 35168-21020
Lubricants:
Grease:AMSOIL Synthetic Multi-Purpose Grease NLGI #2
Brake Lubricant:Permatex Silicone Ceramic Extreme Brake Parts Lubricant
Exterior Light Bulbs:
Low Beam:(2021) Morimoto 5000K H11B HID
High Beam:Morimoto 2-Stroke 2.0 9005 LED
Front Turn Signal:Wagner 3457NA
Fog Light:(2021) Morimoto H11 XB LED
Tail Light:SpyderLED ALT-YD-TCAM07-LED-RC
Rear Turn Signal:Toyota OEM
Reverse Light:(2021) VLED 921_6_HO_2
License Plate Light:SUPERBRIGHTLEDS 194 LED CAN 4500K
Interior Light Bulbs:
Dome Light:SUPERBRIGHTLEDS DE3157 LED 4000K
Glove Box Light:SUPERBRIGHTLEDS 74 LED 4000K
Shift Light:SUPERBRIGHTLEDS 74 LED 4000K
Interior Door Light:SUPERBRIGHTLEDS 194 LED CAN 4500K
Map Light:SUPERBRIGHTLEDS 194 CAN LED 4500K
Trunk Light:(No specific brand) LED Strip with 194 Bulb Connector
Other Maintenance Items:
Spark Plug:Denso IK20TT
Serpentine Belt:Continental 4070752
PCV ValveToyota 12204-28030
Fuel System Cleaner:Techron Complete Fuel System Cleaner
Left Windshield Wiper:Denso Designer Series 24"
Right Windshield Wiper:Denso Designer Series 19"
Banned
Corolla, Camry, Tundra, Camry, Avalon, Highlander, Venza, Highlander
My 2az-fe;
Washer fluid: walmart generic equivalent with similar Rainx tech
Oil: 0w40... engine just sounds better with thicker oil
Coolant: Peak Global but switching to Zerex blue
ATF: Too many to remember.... Valvoline Import Full synthetic for next drain/refill soon
Brake fluid: Honda DOT3
Power steering fluid.... Lubegard PSF, siphon/refillled probably 20x with 20 different synth ATFs/PSFs over the years
Oil filter... Full synthetic media only.... Napa Platinum PFL41516... yeah its big! I wouldn't even consider using the paper cellulose cardboard M1 filter! Obviously, bought a dozen when on sale.
Grease: haven't greased much but hit a few squeaky hinges with lithium spray can stuff.
Brake grease for pins. Red Label Permatex Silicone Ceramic Extreme or CRC Silaramic
Cabin air filter... STP 'cause Autozone carries it cheap enough
Engine air filter... can't remember. All my cars have AFE or AEM or ??? washable air filters. I'll have to look at it for the next cleaning.
Antiseize..... haven't used any in that last 160k miles. Dont need it.
Dielectric grease.... haven't used any but keep a can of CRC aerosol spray can
ATF filter .... dealer sourced ATF filter, oring, magnets, and pan gasket.
Low/Highbeams...... ol' HIR bulbs
Reverse bulbs.... Cree XDB 50w equivalent 921
Interior... various LED
Brake... LED either Sylvania or Philips
SparkPlug.... Autolite Iridium X, because many suffer from Autolite Derangement Syndrome... never failed me yet.
Belt... Bando
FI cleaner.... whatever PEA brand on sale and rotate among brands
Wipers... Michelin Endurance XT Silicone formerly Piaa Si-Tech
Great job on the lighting Van! You’ve done much more than I did, but I can vouch for VLEDs and superbrights. I used them for interior, glove box, trunk, reverse and license plate lighting.
1 - 3 of 3 Posts
