1 - 4 of 4 Posts
This has been naggin at me and wanted to hear if this is just too coincidental-
Took '04 Seq in for water pump, timing belt, tranny/diff/radiator flush at 84k miles. Get it back and 2 days later I pop a CEL followed 1 sec later by TRAC OFF/VSC lights. Take back to dealer am following day and they say skid computer is Tango Uniform and give me a 1200 estimate to repair. I ask if ABS is operable, get the thumbs up, and figure 50 cents of black tape will solve the light problem until I recover from the $1300 paid to do the preventive maint they did 2 days ago.
Then I did what we do with the flight computers in a fighter jet- unplug and reinstall. So I pulled the harness off for a minute (key off) and reinstalled. This resolved the lights and they have stayed off for 500 miles/10 days.
Curious to see these lights w/in a day of dealer service...not saying it was sabotage by the dealer but wonder if the software has a bug that can be stirred by the dealer mucking with the OBD...
At least there is now a possiblity for TRAC OFF/VSC light reset!!!
which harness were you referring to that you pulled?
I've been running with my VSC/Trac Off lights on since I bought mine used in Feb. Everything else runs fine. Wanted to change brakes, struts, and get an alignment before I actually tried to do a Zero Point calib.
Discussion Starter · #4 ·
Memory (albeit like that of a steel sieve) recalls a 12xx DSC but not sure (paperwork in 19k lbs of household goods in a move right now).
I pulled the harness off the skid computer that is on the passenger side of the engine compartment that has all the brake lines running into it (like 7 of them?). So far (a month and 1100 miles later) this appears to have done the trick.
Let me repeat this- pulling the harness off and reinstalling fixed the VSC/TRAC OFF lights.
Our satellites have bit flop error nearly every time passing thru the S. American Anomoly (that's why we turn them off there in a low earth orbit)and while I can guarantee my Sequoia was not 400 kilometers above S. America, I will not rule out a 1 pretending to be a 0 and tripping the bit error code....FWIW....
1 - 4 of 4 Posts
