Hi, I was wondering if it's normal for the water to take 2-3 seconds to squirt out of the nozzles, which is enough time for the blades to go all the way up and back down against a dry windshield. Also, the pump seems pretty weak, only squirting water to about halfway up the windshield, but the wipers carry the water up anyways so thats probably normal. I'm mostly concerned about the delay, as I'm scared of scratching the windshield. Also when I bought the car, the pump was broken, and it was replaced by a shop, so I'm unsure if it was OEM or not. Thanks!
Also, its an 05 Corolla CE. Should be the same between all of the 9th gens, but just in case it isn't, there you go.
