1 - 9 of 9 Posts
Hi, found a lot of water in trunk. Is this just likely the trunk lid seals? Are they after market and DIY? Thanks for any suggestions, Ed
Following cause I have water in my trunk too but I can figure out where from. Mines not from the seal though.
Super Moderator
2006 Corolla XRS
Do you have a sunroof? If you do, I would suspect the drip tubes are leaking. The tubes run down the C pillars and into the trunk. Is your headliner getting damp when going thru a carwash or during a rainy day?
What specific area of the trunk is seeing the most water? Check the drip rails on the roof. Check for gaps along the length and check for damage on either end.
Remove the trunk liner from the trunk and inspect the bottom for signs of moisture.
Checked and double checked I can see some water marks coming from right under the rear window. I have my whole trunk apart for a while trying to find it.
Discussion Starter #7
What part of the back windshield has the water marks? Was it ever replaced?
The sealant may have broken down. Maybe some waterproof silicone could help with sealing. Otherwise, it may need to be replaced.
Sometimes this car's driver goes to a car wash. She forgot to tell me that. I'll have her check before/after doing that.
Diehard Rams Fan
So does the OP have a sunroof? The big culprit for water in the trunk can also be the seals around the taillights.
1 - 9 of 9 Posts
