You too seem to have a blockage for whatever reason. Frequently a thin wire will dislodge dirt. Of course do not just jab a pointy wire up there. I like to do this sort of stuff on the hoist.
The leaking inside is likely due to the fact that the evaporator enclosure is not water tight. They are not meant to contain liquid. Some cars worse than others.
It can be a simple case of a label falling off an internal part. Or some assembly goo falling in. Some assembly line or manufacturing related process may introduce something that eventually clogs the little drain hose. Some cars have two drains. Not ours it seems.
In the old days, before cabin filters, I used to spray Lysol in from time to time....
It may be worth removing the filter. Look inside. Smell. Wipe it out. Spray something. Fabreeze, Lysol, Alcohol (as you suggest.)
Point is some cars have drains that are restricted or blocked. Look for the telltale drip. I look for it from time to time..... I have no weird smells....yet.
I like to empirically check that the solution I implement has worked, so I have a small brushed cleaner wire (glorified pipe cleaner with a soft end) ready if the problem appears again, and am thinking of scoping the line upstream if it does. That should either show that the solutions worked, or show what the problem is. That being said, this vehicle is in warrentee so the dealer/Toyota is responsible for the fix. I will update this thread if there are any other developments that can help others solve this issue.
