heh. do you have a 7m? BHG time. mysteriously losing coolant with lots in the overflow tank. gets pushed out into the tank which overflows. sucks a little back in when it cools but it's a net loss.
coolant won't visibly flow unless it's at just the right level and you have floaties. it comes out the upper hose then spreads out across the whole top of the radiator to flow down. also, you won't see any flow till the thermostat opens.
the stock temp gauge is retarded. it goes up to the middle at around 130f and doesn't budge till over 230f. that means if it does go higher, it's already overheating. meaning unless somethings really messed up it never will move.
