Long time observer here and have learned much from good advice and insight provided. Looks like maybe this is it for my 90 Camry Wagon with 145k miles. Loud continuous engine noises at startup today which I thought was my noisy alternator. Steam wafting up from the engine bay and coolant dribbling on the ground.
Guessing it's water pump replacement time. Called local garage and they said it could be anything without seeing it, but quoted $575 to replace water pump and timing belt (recommended at same time). Also have to make a decision if worth keeping this great car as not having the technical expertise and tools most here do. Then if having this done, it may be a continuous queue of next failing components due to age and wear.
Wondering if quote is in ballpark and what's next likely to fail based on age and other owner experience. Any thoughts appreciated.
