1 - 12 of 12 Posts
Can someone confirm if the engine needs to be taken out for the water pump to be replaced.
Water pump going bad and dealer is telling me they need to remove the engine instead of just removing the alternator to get access.
Depends. Did you look at it to see how much space there is?
Checked out some youtube videos and they didn't have to remove the engine. One video had to jack up the engine from the bottom and the other went through the passenger wheel well.
Would of been better just to buy a Corolla, easier access replacing parts.
Then you can either take it to a different dealer or a local shop. The "proper" way most likely lists removing the engine but it can most likely be done while in the car just after a lot of struggling. Your choice.
The one YouTube video I've seen the owner removed the front bumper and other components to get to the pump. It was almost like doing accident repair.
You can look at it this way, it is a Corolla, Matrix engine installed in a smaller engine bay.
Official PITA
Solara 'Vert & ES350
I seem to remember a GM car from the 1970s where you had to remove engine, or several motor mounts & jack the engine up - to get to some of the spark plugs... and that was back before iridium plugs, before platinum plugs - 30k miles and change 'em.
3.8 Carbed? I recall that Pat Goss mentioned on Motor Week, that one particular oil leak on an older 3.8 GM V6. the engine had to be disassembled to be able to reach the internal seal to replace it.
Discussion Starter #11 (Edited)
Update - Had the dealership replace water pump, serpentine belt and PCV while they were in there. Out of pocket $1,450.00. It isn't too bad since this was the only major fix since owning it in 2008. Typical DD car.
Asked other independent shops and was quoted around $1,200-$1,900 just for the water pump.
1 - 12 of 12 Posts
