1 - 5 of 5 Posts
4runner
The water pump on my 98 camry just went out. The guy that towed it said since the water pump went out that the timing belt is broken. Is that true? What would be the piece of a new pump?
Mad Scientist
94 scepter coupe
this is what you need since you'll be there you can save your self the hassle of having to pay to get it redone:
water pump costs about 32.96usd
crankshaft seal about 5.48usd
camshaft seal about 4.48usd
valve cover gasket w/plug seals about 19.98usd
and the timing belt about 37.28usd
if you change all those then you won't have to worry about those till your next belt change:D
On The Street
do them both since they are near each other. Last year my water pump started making a clicking noise.-as i was told by toyota- and then i took it to my cusin and it turns out the timing belt needed a change. so i went ahead and had both changed.
1 - 5 of 5 Posts
