just paid $214 to a yelp recommended ase certified a/c specialist to tell me my a/c system is broke and needs to have everything replaced at a cost of $1600 total, including the 214 i already paid for the discharge/recharge and diagnosis.
needless to say, i got the car back quick.
here's the symptoms, maybe someone can help me figure out what to do next.
first few minutes, a/c works fine (as i'd previously posted but can't find that post now).
then, slowly it starts acting like i turned off the compressor manually. the air goes from 38 degrees to 80 within a span of 10 minutes, after working fine for 20 minutes or so first thing in the morning.
when it stops working, both lines are the same temp.
the vent air stays the same. the compressor still pumps fluid as i can see small amounts of movement in the sight glass. the compressor clutch engages as it always has.
per the tech, after 30 mins, the pressures went from 35-0 low side and 220-190 high side.
he said that represented a blockage, which he said mean the compressor had let go and was circulating stuff in the system stopping it up somewhere.
1. can a bad a/c compressor work fine for 20 mins every morning and then quit working?
2. why would you still have 190lbs on the high side if the compressor isn't compressing?
3. why are both lines the same temp instead of cold and hot like they are when the system is working fine?
i'm looking hard at the txv but he said he'd have to replace the compressor/txv/drier and flushing the lines and recharging.
does that sound correct to anyone?
tony
tony
