1 - 12 of 12 Posts
1992 Celica GT
Well, tonight I took on the task of finally putting the b+g springs on but I found a problem. So far I ahve the fronts done and installation went swimmingly. Before I started on the rears I figured I would take it for a spin around the block and now I believe I have bad fender rub while turning, not at all speeds only when you throw it into the turn. I wasn't even going that hard into them but still. My tires are 195/60/15 and the wheels have about a 45 offset. Any suggestions are greatly appreciated.
1992 Celica GT
Well the wheels are 15x6, but I needed a small spacer in the back to clear the strut. I've always heard the 38 for wider wheels.
I know I dont have to really roll the indise of the fenders, I believe its rubbing on the actual edge of the fender instead of the bit of metal turned up on the inside, maybe a little flaring is in order
The Return of the Red Coupe
2010 RAV4 V6
Yes, 38-40mm offset is max on the AE92s... that and 195/60-15 is way too tall for the car... I have 195/55-15s on the back and I still think they're big balloons... I can just imagine 60 series. :yikes: :lol:
But yeah, high offset wheels and high sidewall tires will do it, put your OEMs back and you'll see the difference. :)
1992 Celica GT
Discussion Starter · #8 ·
yeahhh I'm kind of screwed with this right now. I have a few options right now, finish lowering the car and see if I can make room in the fenders, get new tires, or I'm thinking about going with the eibach springs.
1992 Celica GT
Discussion Starter · #10 ·
yeah really, those things are ridiculous.
Well I'm going back to stock springs for a while I guess. The springs are ok but seem to bottom out a fair amount(with newer struts on too) and are more of a drop than I was looking for/thought they were going to give.
Slacker Extrordinaire.
1992 Corolla DLX 4D
ahh whatever im running 175/65/14 with a +35 offset and it does just fine..:p
1 - 12 of 12 Posts
