Called Toyota and was quoted about $200 to flush the fluid in my 2012 Camry 2.5L.. Brought it into the dealer who did not want to flush it, instead wanted to drop the pan and change fluid (7 quarts fluid), add 2 magnets and pan gasket which ended up costing almost $400. Person who quoted the original price was from a different location which sets up appointments for the local dealerships.
Got the same spiel previously from the dealer stating this does not need to be done for 100K but I told the dealer I want it done because I expect to drive it 200K. I am at 80K.
After seeing the process on U-tube the dealer now goes through just to check the fluid, I can understand why this is a $400 job. They previously did the flush for about $200. This was before they came out with the ridiculous process to check the fluid level at operating temperatures. Hopefully the engineers can correct the design on future generations. My 2013 Highlander has a dipstick and my 2004 Ford Explorer has a tube in the pan just like the Camry but temperature compensation of the fluid level is not needed.
