3101 - 3120 of 3200 Posts
2016 Toyota Corolla
You must not have ever installed lowering springs or a front strut brace. If you had you would have seen the pop out for checking/adding brake fluid. :ROFLMAO:
No. I don't want to bother with lowering an already low car. My 99 intrepid had a ground clearance of 5 inches and I cringed everytime it scrapped over these high speed bumps we have in my country for the winter time. Eventually I'll have to replace the suspension and that, hopefully, will be easier than doing it on my old rust bucket
Diehard Rams Fan
The Corolla is an already low car? :ROFLMAO: :ROFLMAO: :ROFLMAO: You can fit your fist between the finder and top of the tire. It's ;ike a 4x4 in stock form. I don't like a slammed car but I do like it to look like it should have come from the factory. :)
2014 Corolla
I actually did this yesterday, but I replaced the studs in the thermostat housing. One of them fell off. The exposed part of the stud and the nut were rusted.
Diehard Rams Fan
I checked the air pressure in my tires. With the temps dropping I knew they would need some extra air pressure.
Reactions: IRanNaked
Diehard Rams Fan
I finally got around to installing the fog lights on my 2017 Corolla iM. When I compared the OEM cover to the fog light cover the fog light cover can be seen through. The downside of this is that the silver paint can be seen throwing off the appearance.
To solve this problem I made a template.
Then cut out black vinyl to cover the silver paint behind the fog light grill.
Here is the fog light installed with the black vinyl.
With the cover installed all is black behind the cover.
turned out quite nice.. like that you did the black background..
2016 Toyota Corolla
Should of just painted it black. That vinyl will start peeling eventually
Diehard Rams Fan
And what is eventually? 5 years? 10 years? Painting would have been a bigger PITA and could more easily chip from road debris. I prepped the surface and this is extremely sticky vinyl that is rated for aircraft use. It's also much thicker than every day vinyl so I'm sure it will be okay. Plus it's behind the fog light housing so I'm sure it will be fine. Worst case scenario is it's easily replaceable so no worries about it to be honest.
2016 Toyota Corolla
Depending on the adhesive and weather 3-5 years. Not sure what aircraft grade vinyl is since aircraft's are painted and don't use vinyl...
2016 Toyota Corolla
If you use 3M tape and clean the surfice with rubing alcohol the adhesive should last roughly 8 years before it starts peeling off
Super Moderator
2006 Corolla XRS
Very clean work. Why was it necessary to use a template? Is the vinyl that rigid?
Diehard Rams Fan
The difference is that aircraft vinyl is thicker and much more durable. The adhesive is much better too. While most larger planes use paint, many smaller planes use this type of vinyl.
Diehard Rams Fan
I did properly prep the surface before applying the vinyl so I expect it to last for 10+ years. My car is also garaged so that will help it last even longer. I don't expect to ever have to redo it.
Diehard Rams Fan
I used it to make sure that it looked clean even though you don't see it. And yes, the vinyl is much thicker and rigid. I use a heat gun to warm it up and allow it to flex better when applying it.
Reactions: 75aces
2014 Corolla
Oil change and tire rotation. Ordered new sway bar bushings to install when the weather is much warmer.
