2781 - 2800 of 2904 Posts
FML
Took almost 7 hours to dismantle and strip to shell
Car Hood Vehicle Automotive lighting Automotive tire
Car Vehicle Automotive lighting Hood Motor vehicle
nephew was able to successfully wrench this fuel tube apart that was brought back from Texas yard
it was a definite struggle to get off...
this what rust in threads looks like in Texas panhandle to Dallas area
or is it some sortof loctite threadlocker substance applied at time of assembly?
there were metal shavings all inside of the other tube this finally came out of
Wood Automotive tire Camera accessory Tool Cable
Automotive tire Tool Bicycle part Wood Household hardware
Circuit component Wood Audio equipment Networking cables Cable
Gas Audio equipment Automotive ignition part Spark plug Metal
Coil Wood Audio equipment Auto part Automotive tire
Coil Automotive tire Wood Coil spring Bicycle part
Reactions: Bryan1 and DrZ
nephew said it felt like it was welded in there!
inspected...
Camera accessory Cameras & optics Wood Rim Bicycle part
Surveillance camera Automotive tire Household hardware Rim Cylinder
Hand Household hardware Finger Tool Wood
Camera accessory Automotive tire Coil spring Household hardware Bicycle part
Camera lens Camera accessory Lens Fluid Cameras & optics
picked this up from autoZone loaner to clean the threads out better, hoping one of the tools will fit proper
Product Motor vehicle Font Rectangle Material property
Tool Gas Musical instrument Gun accessory Audio equipment
1997 Corolla
Very likely one of the metric sizes. You don't want to force it if you are not sure of the size. You can use a thread gauge on the male threaded part to find the thread pitch.
Any idea if this is a corrosion issue caused by two dissimilar metals?
I've read somewhere that is a thing
1997 Corolla
Probably not galvanic corrosion. That requires dissimilar metals and an electrolyte. Maybe just good old fashioned corrosion from moisture.
it was actually the black 1/2 that fit well, at least for the end that goes into the fuel pump bracket side
the other side none of those tools fit for some reason, too small or too big
it was a record high 60s here yesterday, was able to get a few hours in on this mess before it got too dark and colder
Motor vehicle Automotive tire Bumper Wood Wheel
Automotive tire Motor vehicle Automotive lighting Bicycle part Bumper
Automotive tire Salamander Organism Wood Insect
undid 3 fuel tankstrap bolts to get the one side down far enough to get at the L-shaped bracket on the lip, the small bolt is rusted bad on that one and 10mm gets no traction onit
Wood Tints and shades Automotive tire Road surface Flash photography
this is what the rear tankstrap bolt looked like, the one that bolts into the open cavity, it came out ok after the initial tightness was wrenched with the pipebreaker bar over 1/2" ratchet VERY SLOWLY
Household hardware Fastener Wood Screw Auto part
compare with new bolt.
Household hardware Fastener Tool Wood Gear
Plant Wood Fastener Natural material Fashion accessory
Household hardware Fastener Wood Spark plug Auto part
salvaged a near-like-new strap at the Texas salvage lot, did not have enough time to undo the other one there, may have to roadtrip back there next year and grab it!
Fluid Table Bottle Wood Automotive tire
the orignial strap was not in TERRIBLE shape but there was definite decay with crusted metal chunks falling out from under the tank band seat that goes over the metal
Grass Plant Groundcover Road surface Soil
Blacktop AE101
I've been thinking about adding some Tom's bits to my car, so I started ordering stuff.
A Tom's Strada steering wheel, which should arrive next week
Steering part Motor vehicle Steering wheel Bicycle part Composite material
Some extra horn buttons because the stock one isn't quite to my liking, not sure which one I'll be using though, these arrived last week.
Wood Wood stain Table Automotive tire Hardwood
And a set of Tom's Spirit C3R in 15x7" ET35, they should arrive in a few months and definitely need some TLC lol. I think just sanding and polishing the lip should do the trick.
Wheel Automotive tire Hubcap Alloy wheel Rim
old return tube & clamp vs new
Wood Twig Eyewear Tool Shotgun
Sleeve Wood Bicycle handlebar Wire Metal
Wood Bicycle part Bumper Padlock Automotive tire
Window Wood Tints and shades Electric blue Twig
Twig Natural material Metal Macro photography Fashion accessory
the finest in sheep fat smothered, no salty slop or water ever touch the precious Toyota Metal ever again
heated to a liquid and poured over into the crevices on the clamp and let it thicken up
Insect Plant Arthropod Pollinator Organism
Arthropod Water Terrestrial animal Metal Fashion accessory
Liquid Water Fluid Drinkware Wood
Brass instrument Fluid Bicycle part Automotive tire Liquid
smothered fat on lip of fuel tank after corroseal converter treatment
new fastener, 'German Torqued' should suffice?
Bicycle part Wood Gas Auto part Engineering
with any crappy luck the whole fuel tank will need to be taken out at a future date to replace evap tube and tank itself
and this whole process will rinse and repeat :eek:
unseasonably warm temps for Dec-1, near record upper 60sF
RH knuckle removed, plenty of head & shoulder room to get at this!
Cigar Tobacco Fluid Wood Office supplies
Wood Gas Metal Nail Tobacco
Fluid Gesture Wood Flash photography Wrist
cleaned brownish out and put timken red bearing grease in
Liquid Ingredient Fluid Drink Gas
Liquid Ingredient Fluid Cosmetics Natural material
Automotive tire Camera accessory Camera lens Cameras & optics Lens
new bellow and clamp
Camera lens Camera accessory Cameras & optics Lens Audio equipment
Token Aussie
1998 AE102 sedan, 2006 ZZE122 wagon, 2018 ZRE182 hatch
Finally back in a Corolla daily whilst the 102 still sits unfinished and unloved in the garage...
Sent from my SM-G970F using Tapatalk
Rolla DX
It’s been awhile but I recently got my Amayama order in the mail with a bunch of miscellaneous and maintenance parts that are hard to come by for a Blacktop in the US. Hopefully this would come in handy to anyone that goes this route in the future plus it’ll be save you TONS of money if you search by part number and none of those bs “kits” online with ridiculous JDM markup
Top row is Blacktop engine parts and bottom row is just random stuff you can’t find at the junkyard in reasonable shape. Plus a bonus OEM portable wheel stopper😎
Font Auto part Plastic Eyewear Transparency
Top row is Blacktop engine parts and bottom row is just random stuff you can’t find at the junkyard in reasonable shape. Plus a bonus OEM portable wheel stopper😎 View attachment 359405
i wish that Amayama would've had the fuel tube the car needs to get buttoned up in the back, they canceled my order, not available
its still stuck in the driveway(n) it seems that Texas tube i picked up had water damage that welded the inner threads and stripped it out too much while taking off to screw the new fuel tube in properly :(
maybe i have better luck outside of Sacramento at the big YotaYard i recently heard about
1993 Toyota Corolla DX Wagon
Grabbed some Russian eBay customs and installed. Still playing with the fitment but happy with the overall look. 2 Side questions: is the speedo digital or a cable on these? The previous owner gave me a cable but I was reading that it's digital. Pulled the cluster and def no cable. Am I tripping? How do I fix the inop speedo?
Automotive parking light Tire Wheel Vehicle Car
Automotive parking light Wheel Tire Car Vehicle
18 XSE Camry, 17 Rav4 LE AWD, 22XT250
looks awesome love a good wagon
Reactions: igotwerms
