5501 - 5520 of 5526 Posts
(previous post #5486
A few days ago, I finished the set of all four motor mounts. I didn't bother with the shift shock absorber, because that's easily doable at any time.
The car was on the stands for 2 and a half weeks, and consequently, the wife (rightfully) on my case for that same interval. That passenger drive axle had been replaced before, so I went in hoping it'd slide right out. No such luck. I ordered a slide hammer. No dice. I wound up having to cut the axle, and then cut it again so the stub would fit into the bench vise. Even then, it didn't press out, it cracked the outer race, and that mid-shaft bearing came out of the motor mount bracket in pieces.
Removing the old mount from the bracket involved a hacksaw, a hammer, and a drift, and then a sanding drum on the cordless drill to recondition the inner surfaces of the bracket.
From there, it wasn't much trouble to press the new mount into the bracket, and the replacement drive axle slid in without the slightest fuss, with some plain grease on it.
Word of advice to anyone tackling that rear motor mount, just plan on cutting that axle out. Hope not to have to, yes, but be prepared to.
Also replaced the fuel filter. That's a lot easier to do with the driver's wheel and fender apron off, and direct access to the bottom of it.
About that aforementioned misfire code; I'd moved the #2 coil (misfire on 5) and saw the code move with it, so I swapped in a new coil, but then the code came back. Inspection of the front 3 spark plugs says it's time to replace them. A set of Denso Iridium TT's is on the way. I'm going to attempt it without tearing down the plenum.
Camry v6 *automatic (yuck) transmission * 98, till the engine blows
New radiator installed, oil changed, tore out back seats, new power steering fluid, break fluid, and to swap rims and install bc racing coilovers, map the wiring from my mazdaspeed 3 to work in camry and solder what I can and cant. And probably pass out in or under the car again because I don't know when to stop.
I like your style already. You motivate me, tbh. (DONT let it go to your head, lol) but I enjoy seeing other who are about that DiY mindset.
Anywho, hows the ol gal running now?
Thanks!
She runs great so long as she's warm. Start her cold and put her in gear, and there'll be a blinking CEL within 200 yards. The plugs have arrived, so that's looking like a project for this coming Saturday. I'm expecting to go through most of my vocabulary of profanity trying to do that rear bank.
I'll also be doing both of the accessory belts. When I was in there doing the rear motormount, I noticed some pretty serious cracking on the PS belt. If that were to snap on some twisty back road, like the one that leads to our house, there could be a real problem avoiding that next tree.
The plugs, belts, oil change kit, and new air filter have all arrived, so it's looking like it'll be a busy weekend. Until then, day job ties up day and evening...
Other stuff coming, too, but I'm hoping to put what I can off until late spring. The weather is already starting to suck here.
Are you on a DIY person or checking engine from time to time to mechanic or repair person annoys you because of busy schedule? Having your own Best OBD2 Scanner Reviews 2020: [Most Popular Scanners List] can be a great help, as it will help you turn off your engine light and identify exactly what’s wrong with your vehicle. Sounds great right? You can save not just your money but as well as time and energy.
99 XLE V6
Parted ways with 3 friends over the last 2 months. Some more painful than others. My boss/friend died late Nov right after I had a falling out with a good friend. Then, my roommates Kia (which already looked like it had fallen off a cliff AFTER getting back home from the shit in 'Nam, was scrapped. I sold him my 01 XLE V6 for 1500. Even though I will see it all the time, it is strange to not drive it. I have effectively had it since 03.
God news is I have a NEW friend who I hope to have a good relation ship for at LEAST 7 years. 08 Avalon Limited with 111k. I like it but almost wish I went with a 9th gen Corolla (XR)S or an SE 6th gen Camry V6. This Avalon is close to my GS430 in some ways and I enjoy driving it too much. 1st world problem? lol.
I doubt I will ever leave the Camry communities, though.
Last week I nearly put her into a pole, destroyed both left tyres and drove home. Then moved house with a trailer and loan tyres the following afternoon lol
pulled out an old alarm system
replaced fuel filter
changed oil and filter
checked for clogged cat by pulling o2 sensor
test drove the car, which wouldn't go over 50mph
parked it, tested the car max rpms in park and neutral, which was 4k
re-checked the timing
fed up with bogging issue I pulled the ECU, and noticed a leaking capacitor
2013 Corolla S
Starter has been hang-firing this last week. Threw in a new one in an hour.
Whoever put the battery cable bolt on the bottom... I have words for you...
... and this swivel socket is GOLD for getting that back starter bolt out. A regular socket and ratchet
will break it loose but you'll be there all night turning it one click at a time without a swivel.
Car started chugging at low rpm, so I started the parts cannon with plugs. Stopped the parts cannon after the first shot killed the problem
291365
while seems like most people are working their subs, i wash and waxed with meguiar's cleaner wax (paste) and painted the grille.
this is the first time i use paste wax, and i am amazed and surprised by how shiny it is. i have been using the spray wax of the same brand (because i was lazy, ha!) but from now on im using the paste.
the grille:
after wax:
the manager at the car wash came talk to me after i waxed the camry. he was amazed how i transformed my from dull-looking to showroom shine!!! made the 2 hours spent at car wash worth it!!!
my friends are visiting from michigan tomorrow, hopefully they will say something nice about how shine it is!
Replaced my 2-stream washer nozzles with fan type, one of the originals broke so I took the opportunity to upgrade. The aim seems a bit low, but I he coverage is good.
2001 Toyota Camry 2.2 w/ 365K miles
Driver window shattered to pieces due to it being misaligned. I went out, in the rain, and by the graces of God found another gen 4.5 graphite grey camry in the yard. pulled the door, went out to the parking lot and replaced the old one.This new one seems to have the same issue, where the side of the window closer to the side mirror rolls up faster than the other side. Any suggestions on how to remedy this issue?
Old door, so many issues I just left it there for anyone who wants it.
293036
