I got two winter tires to be mounted sometime soon. Petlas Snow Master 235/45r18.
It is vinyl from a rollIs that an overlay or vinyl ? Pre cut or from a roll?
Wow. Nice job. I don’t think I could do as good of a job. I e worked with that stuff before but I never needed to heat it. I might try it.It is vinyl from a roll
I’m guessing they are for the front?View attachment 400148
Good time for a coat of wax or ceramicTechstream cable arrived... played with a few settings (ie disabled the seatbelt buzzers in the front) cleared some old error codes and will watch to see if any come back.
And tucked the car in the garage to hide from Fiona. Looks like we are going to get hit overnight Friday.
I had XR plus 70 put on the front a few months ago. Keep an eye out on the upper dot matrix area near the visors, mine started separating from the shop driving home. This was my 5th vehicle and 2nd windshield done by the same shop so I know their level of work. But they should have blue taped the entire top edge up along the dot matrix this time.Windshield later on.
Been awhile just wanted to report in on the Axle-Back Exhaust. Nothing, I canceled the order back in August sometime and no longer interested in making my car sound annoying.Have not done much to my 2022 SE since I bought her last November. She currently has 1743 miles and driven one to two times a week. I did install the XSE dual exhaust several months ago but wanted something more. Searched the internet for a muffler replacement that would be OEM replacement with a little more aggressive sound that will not break the bank and if it sounds like shit I can always put the stock ones back on. I like the MagnaFlow exhaust but sounds a little too loud and too expensive. What I found was Top Speed Pro 1 Performance Mufflers.
Top Speed Pro1 Toyota Camry 2.5L 3.5L 18-21 Axle-Back Exhaust (topspeedauto.com)
I called and confirmed that it will fit my 2022 SE, so what the hell I pre-ordered them. Does anyone have these mufflers or any run in with this vender? I checked them out on YouTube and they sounded good and not too loud or obnoxious.
Top Speed Pro1 Toyota Camry 2.5L 3.5L Axle-Back Exhaust - YouTube
Let me know what you think?
How much did you paid for the tints?Tint. Finally. Got me in quick. Highest grossing Washington state seller/installer of XPEL HR ceramic and a near perfect experience up and down. 15 sides 5 rear. Windshield later on.
California Tint is their name.
490$How much did you paid for the tints?
That is very cheap for Xpel Tints. This is the Xpel Prime Plus?490$
On the RX there is no cover either.Bought the MotivX oil filter housing removal tool in advance of my first oil change since I bought the Camry...
Did the oil change...
When I got underneath to remove the splash shield to access the filter housing... uhhh... something's missing. Buy used, get used.
Also bought a Kirkland battery at Costco... the one in the car is dated 2017, and I work from home so the car sits a lot... also ordered a spare battery tender lead so I can more easily charge the car once a week if its not being driven.
Car is just rolling over 140,000km, next up is the spark plugs (Denso from Rock Auto).
Changed spark plugs. 2018 XSE V6. Car is at 139,861km, I bought it used around 130k this year. I follow the Car Care Nut's video on 2GR-FKS spark plug change.. bought a replacement OEM intake gasket and throttle body gasket as per his recommendation... plugs are same as OEM (from Rock Auto) Denso.
Intake port 'unveiled'... a few drops of oil
New intake gasket...
Cleaned the throttle body, new gasket... watched the Car Care Nut's video on throttle body cleaning first to make sure I was working with knowledge not assumptions...
Spark plugs removed... bottom right is rear right from standing in front of engine. Bottom left is front right from standing in front of engine. Still had some life but fair game for change at 140k km.
All buttoned back up before the engine cover goes on. I took the opportunity to clean some of the dust, dirt, and grime off the visible parts of the upper engine. Car started up like normal, guess that means I hooked everything back up!
Also changed the battery, H6 from Costco (Kirkland). Best price/warranty I could find. Original was dated 08/2017 and at 5 years, with almost 140k k
I really enjoyed your post. Thanks for the pics.Changed spark plugs. 2018 XSE V6. Car is at 139,861km, I bought it used around 130k this year. I follow the Car Care Nut's video on 2GR-FKS spark plug change.. bought a replacement OEM intake gasket and throttle body gasket as per his recommendation... plugs are same as OEM (from Rock Auto) Denso.
Also changed the battery, H6 from Costco (Kirkland). Best price/warranty I could find. Original was dated 08/2017 and at 5 years, with almost 140k km on the car, and relatively unknown maintenance history... I "invested".
