141 - 160 of 163 Posts
Super Moderator
2005 Corolla CE
Discussion Starter · #141 ·
Today I went out and tackled another nagging issue. A slightly rough idle and high fuel trims. I pulled the MAF sensor which looked clean on 1st glance. Upon really close inspection, I found a very small amount of dirt on the hot wire. Cleaned it up and trims are back to less than 5%!!!! Huge win. Also cleaned the oil from the prior leak and now she looks perfect. Really happy with the last few days.
Super Moderator
2005 Corolla CE
Discussion Starter · #142 ·
Got the VVT-I connectors replaced. Wasn't too hard but the passenger side connector literally disintegrated.
Also removed the hydrocarbon filter because it was saturated and likely not doing its job anymore.
Super Moderator
2005 Corolla CE
Discussion Starter · #147 ·
Super Moderator
2005 Corolla CE
Discussion Starter · #148 ·
Installed a backup camera into my E7009 Navigation. Bought an eBay harness which made the camera nearly plug and play. The only things I had to do were ground two wires and tap one into the reverse lights. Any 12V camera will work so I picked one off Amazon with good reviews.
The job itself was a massive PITA because it's an SUV with reverse lights on the tailgate. This made running the wiring in a manner that was clean extremely difficult using the path Toyota used for the rest of the rear harness. I ended up disassembling a large portion of the driver side trim and running the camera harness through the windshield washer grommet. After running everything, the wire was a tiny bit too short. So I grabbed an old RCA connector set and extended the cable to the Navigation unit. Took around 10 hours between figuring out mounting, wiring, and doing it.
Totally worth it. I cannot believe I took this long to do this. I also have a microphone coming so I can finally have my Bluetooth calls work.
Super Moderator
2005 Corolla CE
Discussion Starter · #150 ·
Did an oil change using Mobil 1 0W40 and a Fram XG3600. Also rotated the tires and did an inspection. All looks good at 259K.
I took a few hours and removed the aftermarket alarm/remote start/wiring octopus that the previous owner had installed a long time ago. Wiring in the door, 3 or 4 modules in the dash/left kick panel and several connections. Crikey what a mess! Then I repaired the harness where necessary. Now the door locks work like they should, and no extra lock/unlock cycles just because you do something silly like remove the key. Anyone want the remains? You pay shipping and it's yours.
2006 Sequoia SR5 4x4
In the last month:
-drained/filled the transmission 3 times;
-painted the roof rack;
-painted the front and rear bumpers with truck bed coating;
-replaced driver's side valve cover gasket, spark plug tube seals, and bolt seals;
-replaced the bulbs in the HVAC and 4x4 controls with LED's;
-installed Westin steel mesh step bars;
-replaced wiper blades and turn signal bulbs for state inspection.
Replaced passenger side valve cover gasket, spark plug tube seals, and bolt seals. Also primed/painted the valve cover metallic blue.
Raised the rear axle vent to the bottom of the floor pan.
Took a trip to Monterey Bay but prior modded the following:
  • PPL
  • Roof Rack
  • Ceramic Pro
  • TRD Badge
  • Raptor Lights
  • Tinted Fogs
338279
338280
Last week replaced the serpentine belt.
Over the weekend I scored a front tow hook, 2 roof rack crossmembers, and a Limited rear spoiler from a local junkyard for $60. Painted and installed the new tow hook today.
Over the coming weekend I am going to remove roof rack so I can paint the bottom and install the new crossmembers. Also going to paint the roof white, like many FJ Cruisers, older Land Cruisers and Land Rovers. When that is done I will install the spoiler, which is also white.
Added the two additional crossmembers to the roof rack, painted the roof rack black, and painted the roof white with a couple coats of 2x clear coat.
340650
Changed serpentine belt today after a all day squeak fest coming from the front of sequoia. Waiting for more parts to come in next week to bring it to a super comfortable driving condition. Rides a bit off right now due to blown rear shocks and what seems to be worn bushing along with loose steering up front.
