I'm still in the process of doing heavy maintenance on this Camry that I just bought. I'm going to change the automatic transmission fluid. I'm thinking about using the Redline ATF. What do you guys use?
Jeeves said:Redline is a good brand. I use all their stuff in every vehicle I own.
If I'm not mistaken, Hayden only makes a fin and tube style cooler. I'd suggest you get a stacked plate type such as B&M. They're much more durable, not to mention maintains fluid pressure.QueensCamry78 said:Yea, I'm thinking about adding the Hayden tranny cooler & do a full flush. I probably will add the Redline ATF or something from Toyota.
thanxPhi said:do a keyword search using the word "cooler" posted by me and you'll find EVERYTHING..including a DIY
You Could If.I'm still in the process of doing heavy maintenance on this Camry that I just bought. I'm going to change the automatic transmission fluid. I'm thinking about using the Redline ATF. What do you guys use?
Rebuilders have Sworn It's Okay To Use Type F for harder shifts after A rebuild. Their Is not A Chance I Would try it. I don't know if Red line Is A Synthetic Only Fluid Or not. If it's Synthetic You can drop the Temperature by twenty degrees. But Your Transmission has some Miles On it. I Would Stick to the Asian Trans Fluid. Another Words I Agree With the Gentleman above My Post.I would use the oem fluid only. This is how I did mine on my 03 camry ,
