Status
Not open for further replies.
1 - 20 of 36 Posts
1999 Toyota Camry
Well, as you guys probably know, i've posted many times deciding on what engine to swap into my gen4 camry which currently has a I4. Well, here it is, have fun and leave some feedback...
V6 Power Baby....1mzfe, 2001 with 22K
Complete Wiring Harness, Uncut...Woohoo!!!
Mad Scientist
94 scepter coupe
but did you get the ecu for it? is it jdm or usd? how much did you pay?
when i did mine i did a full overhaul on it all gaskets timing belt and cleaned the intake manifold and tb. but you'll like it a whle lot better than a i4:thumbup:
S14 Fever :D
1993 Toyota Scepter
Cool man:thumbup: How much did the engine cost you, and is it JDM or USDM?
96 3MZ M/T
Camry
when you get her in the car hose her down and spray a nice coat of armor all on it makes her really shinny really wick :D also makes her collect dirt fast as hell
Auto-Cross Addict
Man, I would do more than just gaskets. Since you have the time, I would do a full cleaning on it. Save the life of the engine, make it life new. And if you have a bead blaster, that thing can be as clean as a new engine:) It's worth the time. And boy does it make a difference.
TN Ass Man
95 Camry SE 2-door
malukalu99 said:
Why go to just a v6? pop a 2jz in there
waste of a engine swap
:hammer: :hammer: :hammer: :hammer: :disappoin
I can see right off the bat the valve cover seal leaks.
dont most 1MZ-FEs have probs with this, because i know i have to clean mine engine off every once in a while because of this
Auto-Cross Addict
You should be beaten!
I forgot to mention, you should do any dress-up before hand. It will save you a lot of time later. Like I am painting the heat shield for my exhaust manifolds. Stuff like that. Easy time to clean:)
Not aure about the valve cover seals. I thought I was going to change mine, but there was no leak. That's with 130k + miles on it. I looked all the way aroud and had the seals before I checked. I might be lucky, but in a year or so, I eexpect to see something coming out.
1999 Toyota Camry
Discussion Starter · #15 ·
For all you guys, the engine is usd, i believe. I paid $1270 which included a 6 month warranty and all taxes. I will be picking up the ecu later. Also, before I swap the engine into the car, i'm gonna mod it up with everything i can while she's out, then put her in.:D
malukalu99, it would be cool to do a 2jz, but you do know that's a RWD, right? that would mean a hell of alot of conversion work to make my camry RWD and it would cost alot of $$$ which i don't have.
other than that, i'll probably end up changing the seals and sanding the engine down a bit to look abit more clean. I also got a friend who does powder-coating and he'll hook me up. But definately, i'm gonna do the mods and dressup before i put it in. It'll make alot easier for me in the long run.
Auto-Cross Addict
You could do the powder coating yourself. I read an article in last months "Hot Rod" on how to do it with a welding torch. Easy shit too. They sell at home kits. But your luck that you have to hook up. I wish I did:(
*Side note* 2jz wouldn't fit without moving the whole firewall back and spending more money than it's worth to mount everything.:)
1999 Toyota Camry
Discussion Starter · #19 ·
a RWD is possible, just need the $$$ to do it. I think Sportivo has a RWD camry (not sure).
oibone781, I'm not sure what i should do with the tranny, but i do know that the auto. in my car now is going and i'm gonna look for a manual to put in. I'll pretty much have a better time and vehicle with the manual and 1mz modded up. Gotta start searching.
Anybody know of any good websites that i can check out to get started on collecting parts for the engine and stuff like that?
Auto-Cross Addict
Yeah, Sportivo Concepts built a Gen 3 RWD Camry TT.
As for a tranny build up, you can have your torque converter beefed up.
*Personally, I would like to see a RWD Gen 3 Wagon. That would be pretty tight.
1 - 20 of 36 Posts
Status
