1 - 13 of 13 Posts
· Don't get mad. Get even.
a Toyota camry, daaa
Discussion Starter · #3 ·
I'm sure you've probably talked about this elsewhere, but what was the mistake you made with the '07?
Looks nice. Are the wheels going to be 18s or 19s? They almost look like 19s in the PS.
Install some piece of shit springs like the "Sprint"...
Wheels 18's nothing bigger, I want some rubber... To keep my OEM overall wheel diameter of 25.492 inches I have to go with 235/40 18 and I'll have an overall diameter of 25.402 just a hair smaller with a 45 profile jusmps to high and the speedometer would read 65 MPH and the actual speed would be 67.128 MPH. I may go with 45 profile 2 miles It's not that much. I think my speedometer It's all messed up already, the 98 comes with 14' or 15' and they have different readings on the speedometer with the suggested tire sizes...
· I HAS BOOST!!!
94 Camry SE V6 Coup
as long as you keep the over all tire and wheel diameter close to the same the the spedo will be fine.
thoes look like 19 u got in the pic so if it were me id go either xx5/45/18 or xx5/50/17. alot of that has also to do with the tire width, the wider the tire the higher the side wall will be. for example, i switched from 215/45/17 to 225/45/17 and the side wall was higher.
· Still confused...
95 camry coupe v6
^^ well yeah, because your initial sidewall height was height was 45 percent of 215 and now is 45 percent of 225.
Meh, you're fine. You started in Show & Share, it was suggested you ask us Gen4 guys & you did the right thing.
Only thing killin' me is..........THAT FREAKIN' CAMRY IS CLEEEEEEEAN!!!!!
It's gonna make baby Jesus cry if you FF that poor beauty!!!
1 - 13 of 13 Posts
