a little insite on making cars go fast.
to make a car go fast, you want power to push it.... torque to get it moving...
to produce torque is easy... it comes with power and power with torque
anyway, BASICALLY, take soem air, take some fuel, blow it up... correct?
now fuel... meh, always have enough, injectors can be replaced to allow more, a surge pump Just incase etc.
the key to making a car efficent and powerful is air.
more air you get, the WAYYYYYY better it is...
this is why superchargers and turbos faring own, if you can force air into the engine, it means that the suction on the intake stroke is reduced, or put into negitives, (aka boost).
only thing that makes turbos make cars go fast, is air.... push air in quick, car go quick.
thats it...
air..
make your car go fast, get more air... cold air has more dense oxygen... so cold... air..
lots and lots of it... thats it... what about nos? yeh.... thats basically oxygen... more air.... helps it burn...
get the picture? more air.... MORE AIR (why quad throttle bodies own... allows more oxygen to enter the inlet manifold). and 20v helps because more air can pass through into the combustion chamber...
AIR!
