On a search, I see people confusing it with the OBD2 connector (which is in the cabin under the dash) -- but what diagnostics are available in this alternate connector, and what diagnostic tool accesses its data?
Most likely Toyota specific with them having the access to the tool, not sure just my best guess. Typically OBD2 is mandated, everything else is proprietary, meaning manufacturer only. If I'm wrong someone will be here shortly to correct me.
As far as I know, it is just an old Toyota diagnostic port. I wanna say we used a Snap-On diagnostic tool that had that add-on but we only used it once and I am not sure what it did. OBDII at this point should do whatever you need so it is best to just ignore the port.
On the older Toyotas with OBD1, you would jumper the TE1 & E1 terminals in there to get into diag mode, where the CEL would blink out the error codes. You could also:
Force the fuel pump to run with KOEO (jumper FP to +B)
Read fueling corrections by probing voltage across VF1-E1 & VF2-E1
Read O2 sensor voltage signals across OX1-E1 & OX2-E1
Read ABS faults (jumper TC-E1)
Force radiator fans to run (jumper OP1-E1)
There should be a label on the underside of the cap denoting the terminal IDs. As time passed, some of the terminal positions were depopulated, so the function was lost.
I think one needs to understand that while OBDII is standardized, there is still a lot of non-standardized manufacturer specific extra stuff that's not part of OBDII standards. You need yet still another scanner, or a much more expensive OBDII scanner to do things like air bag, abs, key fob programming, and these functions would be different for different manufacturers. The standardized OBDII stuff has more to do with emissions.
Hi All, this is my first post. I have a 2000 Avalon with 260,000 miles on it. It was my dads car and I have inherited it. I've heard about the oil sludge problem and have always changed the oil at 3,000 miles. I was tempted to use a engine flush product in hopes that it would help clear up and...
I just noticed some leaking oil under the hood on my 2001 Toyota Avalon xls with 117,000 miles on it. I'm not very knowledgeable when it comes to vehicles. Any advice would be wonderful. I included a picture of when I purchased the vehicle with 108,000 miles on it and a current picture.
Hey guys I have a 2000 Toyota Avalon, just need the torque specs for:
1. Transmission Drain Plug
2. Transmission Pan Bolts
3. Transmission Filter Bolts
I've looked around quite a bit but can't seem to find them for this car and I don't want to cause damage or leaks by over/under tightening...
I recently had the water pump, tensioner, thermostat and radiater cap replaced on my 2004 toyota avalon. After 1month/2000 miles. It is leaking badly. After removing the tire and inside cover, It looks like it could be from the water pump but, cannot tell w/o disassembling. Does anyone having...
I recently broke the flip-out portion of the armrest on my bench seat 2002 Avalon. Does anyone know a source for this part? Any help will be appreciated.
