What size tires are you running?
H Rated tires are only rated to 130mph. V are rated up to 149mph whilst Z are rated to over 149mph.
Personally, I always ran 245/45/Z-16s on the Supra. For those not up date on how tires are spec'd, here's a brief rundown:
245 - is the tire width in millimeters. (9.64 in)
45 - is the sidewall ratio, always expressed in a percentage of the width. (4.34 in)
Z - Speed Rating (149+mph)
16 - Size of wheel the tire is meant to mount on.
A simple calculator can be found
HERE.
Enter the tire information, and it will detail the size and information about the tire. If you enter a second tire size, it will compare the two.
