1 - 20 of 20 Posts
Hi everyone, don't know if this has been posted before, but what is that tube I marked in the picture for ? Can it be removed ? I believe it is connected to a canister behind the bumper, but on my car the canister is broken. The car has been like that for 10 years or more. It is on a 2005 corolla xrs. Thanks.
2008 Corolla CE
Welcome Frank.
What country are you in? It will help us determine what it is.
My bet is pollution control of some sort.
Super Moderator
2006 Corolla XRS
Hi everyone, don't know if this has been posted before, but what is that tube I marked in the picture for ? Can it be removed ? I believe it is connected to a canister behind the bumper, but on my car the canister is broken. The car has been like that for 10 years or more. It is on a 2005 corolla xrs. Thanks. View attachment 283383
That is the tube for the secondary air injection system. Monkey wrench racing sells a delete kit. This is only used during cold start up while the system goes into closed loop.
Thanks. Mine has the connection to the tank broken since we bought the car back in 2007, and it annoys me whenever I turn the car on and it makes a really loud sucking noise for about 30 seconds. Couldn't find the delete kit on the monkey wrench website, do you happen to have the link ?
Super Moderator
2006 Corolla XRS
Here you go. It's called a plug kit.
Discussion Starter #9
Just bear in mind, this is part of the emission system. If necessary, then you'd have to find a replacement part. A Corolla xrs just showed up in a junkyard near me.
On mine the pump broke where the hose connects to the pump. I could either try to repair it or find one in a junkyard.
Discussion Starter #13
Unless you are required to do emission testing, then a replacement part will be needed. If not, then the delete kit will work.
Here in Puerto Rico we are required to do emissions testing, that is why I want to fix this.
Super Moderator
2006 Corolla XRS
Ok.
Is the damage only limited to the housing inside the box or is it at the air injection tube?
Edit : re-read your original post. You may need to use eBay to source the canister of the air injection system. Monkey wrench racing only sells the air injector. I haven't taken mine apart, but is it just the housing that's broken? Any cel for the air injector?
Discussion Starter #15
Ok.
It broke where the box and the tube connect, so the inlet of the box is still inside of the tube. I believe that with some time and epoxy I may be able to fix it. My main limitations are time and lack of tools/mechanical experience.
Discussion Starter #17
Okay. Then eBay will be your best source for the assembly.
Thanks, I will look around ebay and see if I can find it. I really baby my car, I always take good care of it and want to fix all the little kinks it has. It only has 85000 miles.
I had the same issue on my car, secondary smog pump code causing me to fail smog. I left my broken secondary smog pump in but just ran an 03 matrix xrs ecu and so far 10k CEL free miles and passed smog :cool:
Discussion Starter #19
I will look into this. Thanks for the suggestion.
1 - 20 of 20 Posts
