I have the base LE with no TPMS, but this "set" button looks like the TPMS icon. What is it for?
Yep.You have TPMS.
tkahrtfm.
Not a real acronym, but nice try.tkah
If you have a 3rd generation HL, double check the proper pressure as mine is suppose to be at 35-psi (Not 30-psi) when cold. TPMS light comes on when one or more tires with pressure drop (see other posts or owner's manual for more detail) will cause the warning light to come on. As one of the member "is250sp" in the earlier post attached a picture on where the Reset button location under the driver-side dash pretty close the Hood release... If I recall correctly, the manual suggested to reset the TPMS after each tire rotation and I would reset the TPMS only after all tires are with proper pressure while the tires are cold to baseline the pressure sensors. My earlier post also have page number for the where about of this info in our owner's manual assuming you have the same model year HL. Hope this helps.so my tpms light came on and went to gauge all tires so now they are all at 30PSI and I even did a reset (no engine) on and the light is still on. Do I have to drive it a bit so it can recalibrate or could it be the spare tire sensor (not sure if it has it on there as some folks says it does and some say it doesn't on spare tires)
Yap, sounds right; approximately more than 4~5 psi drop will trigger the TPMS warning light to turn-ON. If you did not rotation the tires, you shouldn't need to reset the TPMS in this case yet it won't hurt and always good to know that your system is working - Yeah! :rockon:thanks guys. it looks like 35psi for cold. It was 29-30 psi when I checked today. I will go set it to 35psi
