1 - 11 of 11 Posts
G
I recently asked about reducing my HC emissions for my smog test in
Texas at this newsgroup. Several of the responses indicated that
they suggested changing from the Bosch platinum spark plugs I now use
on my 91Camry LE. They suggested using NGK and Denso. How are
these plugs better than the Bosch plugs. Are they constructed better?
Is there any proof that one brand is better than another?
G
Discussion Starter · #2 ·
Engine designed with NGK and ND plugs.
Some have experience poor performance with non-NGK/ND plugs.
You may have other problems not related to the plugs, but might start with
using the recommended OEM plugs.
G
Discussion Starter · #3 ·
Several years ago I replaced the plugs in my Sister's Honda Civic. I let the
salesman at AutoZone sell me a set of Autolite Platinum Plugs for the
engine. I installed them and the engine appeared to run fine. However within
a day the check engine light was on and the engine was running in limp home
mode. I checked the codes and it was suffering from random misfires. I
pulled the plugs, checked the gaps, reinstalled them, and cleared the check
engine code. Once again the engine appeared to run fine. However, the next
day the check engine light was back on and the engine was running rough. So
I pulled the Autolites out and replaced them with the recommended AC plugs
(only thing I could fine easily on a Sunday afternoon). Again the car seemed
to run perfectly - for one day. The next day the check engine light was on
and the engine was running rough. So, I went to Pep boys (horrors) and asked
for the NGKs listed in the owner's guide. I installed these and no problem
for 50,000 miles.
So what can be different? Heat range, resistance, insulator configuration,
reach, gasket configuration, etc.,etc. For whatever reason Japanese engines
seem to be very sensitive to minor variations in sparkplug design. For my
Fords, I buy Motorcraft. For anything else I try to find the plugs specified
by the manufacturer. If the manufacturer's recommended plugs aren't readily
available, I buy NGKs if they offer them for the application. Under no
circumstances would I use the Bosch plugs in a Japanese vehicle. And I
absolutely refuse to even consider using the multiple electrode Bosch plugs
in any application unless specified by the vehicle manufacturer.
Ed
"Al Kondo" <[email protected]> wrote in message
news:[email protected]
G
Discussion Starter · #4 ·
High HC with low CO can mean a plug problem, and it's safest to use one
of the plug brands listed in the owner's manual, or at least use
Japanese plugs in Japanese brand cars, American brand in American brand
or Chrysler cars, and Bosch in non-Chrysler German brand cars. Also at
least some Hondas seem to need NGKs, but Toyotas should do fine with
Densos since Toyota owns much of Denso.
G
Discussion Starter · #5 ·
>for 50,000 miles.
>Ed
Another man who puts supreme confidence into a manufacturer's
recommendations...great!...the right stuff indeed...who knows his
engine better, him, who has spent thousands and thousands of
dollars in designing, tweaking and fine tuning that engine to a
fare-thee-well or some brash teenager with an overblown sense of
confidence and a bee in his bonnet that whispers 'you know best'?
-Gord.
(use gordon in email)
G
Discussion Starter · #6 ·
Have you ever looked at the positive electrode on the Bosch platinum
plugs and compared it to the ND?
The Bosch platinum electodes are almost microscopic - the amount of
platinum is very small and the cross section of the firing tip of the
electrode is very, very small.
The original equipment ND uses a more conventionally sized electrode
with platinum plating that extends from the ceramic tip, whereas the
Bosch is flush.
At 60,000 miles, the ND still looked fine and the gap was still good,
last time I changed mine.
If you check the gap on the ND plugs, would recommend go or no go type
wire thickness gauge so you avoid scratching the platinum coating.
So, yes, they're constructed differently and one is better for your
Toyota.
The main point is that many people have experienced problems with the
Bosch in their Toyotas.
High HC (hydrocarbon) readings on an emissions test is simply unburned
fuel.
G
Discussion Starter · #7 ·
> Bosch is flush.
> Toyota.
> fuel.
Yeah, I noticed when I put Bosch's in I just passed HC, and then when I
changed back to ND's the HCs went *WAY* down!
Have your Virtual Pet spayed/neutered!!
G
Discussion Starter · #8 ·
> for 50,000 miles.
DON'T USE CHAMPIONS!!! 1978 Corolla w/40K, decided to give it a tune-up.
Damn thing wouldn't start if the temp was below 50 degrees!!! A trip to
Foreign Autoparts for NGKs fixed it right up. I don't even use Champs in
lawnmowers anymore!
G
Discussion Starter · #9 ·
> lawnmowers anymore!
gotta agree but used to own big block dodges
wouldn`t run on anything but champions
NGK or Denso in Toyotas
G
Discussion Starter · #10 ·
> Bosch is flush.
The almost-microscopic flush platinum electrode is supposed to heat up
easier and therefore ionize the air more readily than a conventional
tip. Really. Why it never seems to work as well as NGK or ND platinum
plugs is puzzling.
G
Discussion Starter · #11 ·
>> Bosch is flush.
Have had Bosch 2+ Platinum in my 2000 sienna for about 10K and never had any
problems, for 1/3 the cost. Don't know why so many people are complaining
about it.
1 - 11 of 11 Posts
