Now that the temperatures are starting to warm up, I'm planning to do some maintenance and one of the things is replacing the power steering hose, or metal tube, that curves around the front and runs low, heading back towards the firewall. I think it's the called the intermediate power steering return hose. I'm also planning on buying a section of rubber hose and swapping it in for the smaller, front-most, hose going into the Power Steering fluid reservoir, which despite having it's OEM band clamp (not to be confused with band camp) And a worm type clamp that I added a few years ago, the darn thing insists on leaking, running down along the hose and making a mess of things. The leak isn't enough to drop below the Low line, but it's irritating and cleaning takes a while.
SO, in addition to replacing the smaller reservoir hose, which I have discovered here on the site is 10mm ID (or using a 3/8"/9.5mm from any parts store), which type of Clamps do you prefer use, what brands do you recommend, and where do you usually buy them?
The OEMs look cleaner, but I find the worm type a lot easier to put on and take off. I guess one plus of the OEM is that you can't overtighten, if you buy the proper diameter for the hose. Once you start using aftermarket hoses, who knows whether the OEM clamps will hold enough pressure.
Thanks in advance and a good and safe weekend for all!
