1 - 2 of 2 Posts
Newbie
Here's a challenge for you:
When I open either door, something in the dash begins to "Tick-Tock" similar to a turn-signal type of click-clack - I say similar because it is different and happens whether the engine is running or not, whether the blinkers are blinking or not (either side) or if the key is in or not, and in any position.
Interior light will come on in "Door" position and go off normally, and both door switches function fine.
The Tick-Tock will continue for ~30 seconds after the open door is closed and then stop....until either door is opened again. Repeat.
Engine and truck operate normally otherwise. I'm in the middle of troubleshooting a starting problem and suspect the ignition switch. Would this be related?
Newbie
Discussion Starter #2
All my problems were tied to an old remote starter that stb. I yanked it out and she fired right up! 3 weeks of messing around with starter, contacts, switches and the like....and it was the remote start.
Why install this in a manual? Really. Must have been done years ago.
At least it wasn't something expensive.
1 - 2 of 2 Posts
