whats worng wid this AC ?
753 Views 1 Reply 2 Participants Last post by  aznstylez
ok so.. in the 93 accord...
when you turn on the AC, air blows thru but not cold air. after leaving it on for a while, the engine overheats.
is the AC unit not blowing in cold air and the overheating two seperate issues ? if it is, i can check the coolant level, radiator, etc.. but then what causes it not to push in cold air ?
if its not.. does anyone kno whats wrong ?
thanks
1 - 2 of 2 Posts
your A/C condenser and unit(motor) might be out. and also, check your R-12 thingymaggia. the overheating, check your coolent and also, your thermostat might be going out.
1 - 2 of 2 Posts
