wheel bs ?
853 Views 3 Replies 3 Participants Last post by  ambush63
Read so many different issues on bs that I'm spinning. Does a 17x9 wheel with 4.75 bs and 33" tires fit on a 6" fabtech lift? Don't want to run spacers. Will I have rubbing?
1 - 4 of 4 Posts
You should definately not have any rubbing with a 6" lift installed. You would however have to do some serious trimming if you ran that setup with a 3' lift. Although I have never run the setup you request, I don't see a problem with rubbing, and probably won't need spacers either.
x2 :thumbsup:
so the 4.75 bs on this wheel isn't going to be a problem?
1 - 4 of 4 Posts
