Do you have info on the offset? Also, it will depend on which tires you mount.Bolt pattern and hub bore are identical.
I remember reading an ET40 but I can't seem to find that info now to confirm it. I think I may just bite the bullet and buy these. For $100 I can't go wrong. Any suggestions for a tire size?Do you have info on the offset? Also, it will depend on which tires you mount.
A 40mm offset will be fine. If they are 48mm (like most Matrix wheels) then you'll want a 10mm spacer in the front and a 20mm or 25mm spacer in the rear. Do a 205/50-16 tire on there - it should be the factory Corolla size once they went to 5x100 hubs.I remember reading an ET40 but I can't seem to find that info now to confirm it. I think I may just bite the bullet and buy these. For $100 I can't go wrong. Any suggestions for a tire size?
Currently running a 185/70/14 on 14" steelies 6" wide with a 40 offset. The wheels pictures above are a 16" x 6" with an offset of 45. If I end up running a 205/50/16 will I still clear struts, etc?A 40mm offset will be fine. If they are 48mm (like most Matrix wheels) then you'll want a 10mm spacer in the front and a 20mm or 25mm spacer in the rear. Do a 205/50-16 tire on there - it should be the factory Corolla size once they went to 5x100 hubs.
-Charlie
Good to know! I will definitely keep that in mind.I've also ran a 205/50 on a 16 x 7" +40 with no problems.
If you lower it with springs or coilovers you will rub the front wheel well plastic liners a little when going over deep dips in the city or at highway speeds.
