casey said:
...i'm a little hesitant about puttin 225\40\17 on the back though, won't they look a little over sized in comparison to the front or will they stick out of the fender at all ?...
I've never stuck that in the rear of my MK1 but I did have 225/40-16s in the rear and they were a perfect fit with my Ronal R20s (ET35). I'm almost positive that 225/40-17s would fit, especially with a 40 offset, those rear wheel wells are bigger than they look. But you can't screw around with the front too much, a 7 inch wheel width is pretty much the max up front unless you do your homework with offsets then you can squeeze in 7.5".
Remember, unlike the MKII, the MK1 came from the factory with all four wheels and tires the same size. You can have fatter ones in the rear as long as your ride is properly aligned but the best is all the same size for that classic MK1 handling. Fatter rear tires may give you more understeer than you're prepared to accept on such a well balanced car.
If you absolutely gotta use spacers, go for it but with an offset like ET40 you don't need them considering the car shipped with ET37. It's always best to find the right wheel offset and forget about add ons like spacers.
Good luck!
