1 - 20 of 54 Posts
ToyotaRIMD
Camry 1999,
I am finding various pieces on above subject, but I am not sure what does work.
Some use during towing. I know some of you may have used N (Neutral) in an automatic gear transmission.
Do you mind sharing the situation/impact?
Does switching to N from D while driving strain/damage the transmission?
What is the situation to use N instead of Break?
Thanks for sharing.
05 C-XRS
I've only used N in automatics, when the car breaks down on the road and needs to be pushed off to the side or towed.
ToyotaRIMD
Camry 1999,
Thanks for your replies. Is "N" alternate to break?
Does frequent "N" usage hurt transmission?
Almost 1/2 Million Miles!
92 Toyota Camry XLE
Thanks for sharing.
My main reason for shifting to "N" on my 1992 Camry XLE 4 Cylinder Automatic is when I need to turn ON my A/C and I am traveling at or above 2,200 RPMs.
I just replaced my A/C compressor about one year ago on this 465,000+ mile Camry without any Engine Rebuilt history and believe it or not my original compressor still worked but the internal pistons where all worn.
I try to turn ON the ENGINE without the compressor and I turn OFF the Compressor before turning OFF the ENGINE.
While in motion, I "Carefully" shift into "N" while releasing the Throttle to allow the A/C Compressor to engage without such high RPMs.
Another time I do place the Transmission Selector in "N" is when the Engine doesn't have the A/C running and ENGINE RPMs fall to the point of feeling the Steering Wheel vibration at a light and the light is taking too long.
Hope this helps.:laugh:
Here is my Camry getting a recent E-Vac and Recharge!
ToyotaRIMD
Camry 1999,
Discussion Starter #7
Thanks for your replies and exposing your 465K miles success story. It is impressive. :laugh:
If you shift to "N", when you were traveling at or above 2,200 RPMs, will RPM comes down.
Is it safe to put it in "N" on such RPM level? Does it hurt the Transmission?
I posted another related to camry 1999, Here the url
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/967097-does-timing-jump-cause-engine-replacement.html
Please review and share your thoughts.
I find "Neutral Drop" cause damage to transmission. Why/where did you do it?
Thanks for sharing.
2002 Ford Focus SE
RPM should go down when shifting to Neutral.
Neutral drop is for high-school kids and show-offs - it can damage the transmission and other things, but it impresses (some) girls - which is more important to them.
Bigger issue is Neutral is one step away from Reverse. On a modern car it won't matter, but on a 2007 or older, if you are going 55 down the highway, intend to shift to N and accidentally keep going to R - you just trashed the transmission.
Personally - I only shift to N if I am stopped at a light and want to smooth out the engine vibrations.
You can move your selector lever forward from L to 2 to D to N and backward from R to N to D without holding the lock release button, so there's no risk going into Reverse (or Park)
M/T lover
'00 Echo
I may or may not do a lot of neutral coasting. Shifting into N won't harm anything, but going back to D warrants some kind of attempt to rev-match.
98 1MZ 98 5SE
I was joking when I put "Neutral Drop".
It was the first thing that came to mind when I read the question.
Been along time since I did any sort of neutral drop. I probably have done a milder version when stuck bad in the snow rocking back and forth or just trying to get un-stuck.
ToyotaRIMD
Camry 1999,
Discussion Starter #12
guapoman2000
You have a good story to share about your 1992 Camry XLE 4 Cylinder Automatic with 465,000+ mile Camry without any Engine Rebuilt history.
How did you get there?
Do mind sharing your driving tips?
What did help to achieve this?
How did you mange your transmission?
Thanks for your sharing.
92 Toyota Camry XLE
guapoman2000
Hello!:laugh:
To me there is really nothing out of the ordinary except I see Camry's that are just in their prime at the Junk Yard with lots of life had it been that the owners would have taken better care of them.
You see, my Camry is a little over 22 years old so, that comes out to less than 22,000 miles per year. Had I not joined a Mass Transportation Group (VAN POOL VEHICLE), I do believe that my Camry would be reaching almost one (1) million miles by now.:surprise:
I love the design of the Engine as these 2.2 Liter work horses are Non-Interfering such that I can just drive until the Timing Belt decides to skip or the tensioner decides to give way and allow the timing belt to go. It has happened many times and I have the Tow Truck number on speed Dial. The ONLY exception to this "is" the Water Pump issues such that you would need to perform a Timing Belt before it reaches the point as I just described above. This is why I flush the Cooling system once a year (late February) to get it ready for the Hot Summer months.
If you are talking about NO RE-BUILT topic then, I believe that changing the Engine Oil & Filter every 3,500 miles is the trick assuming Natural Oil (non-Synthetic). Additionally, using High octane Gasoline with blended cleaners will do a few things for your Engine such as keeping the Injectors clean and will keep your Oil from breaking down since the higher octane will perform better and not cause your injectors from getting ruined such carbon or unburned deposits of gasoline reach your Engine Oil.
From other cars that I have owned (many), the typical car killer list is:
1). Driving very short trips
2) Not allowing the Engine to warm up.
3) Not allowing the Transmission to warm up before slapping it in gear.
4). Bad fuel injectors (leaking)
5). Bad spark plugs, wires, Ignition System.
6). Bad O2 sensors telling the car to run rich.
7). Not changing Engine Oil & Filter depending on the use of vehicle.
8). Not flushing Cooling System at its routine schedule.
9). Not performing Automatic Transmission flush at its routine schedule.
I would say that the best is to keep an eye on all fluids, especially the Engine OIL Level and Condition. I say condition because there could be a possibility that Fuel injectors could start leaking and now your Engine Oil is mixed with fuel and that is not good for the Engine if you continue to drive without noticing.
Here is the result of keeping your Engine Oil up to date!
Picture taken from this post:
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/338662-what-did-you-do-your-camry-today-273.html#post4847113
It is amazing that at 465,000 miles my Camry has the original Rack & Pinion, Fuel Injectors and complete Exhaust System (with the exception of a recently replaced Oxygen Sensor). Original Alternator reached 265,500 miles, the factory A/C Compressor was still working (internal pistons were just too worn) and was replaced right at 300,000 miles.
I have performed the Automatic Transmission Flush about 65,000 miles ago and it is coming time to do it again. I take it to a shop with a modern flush machine and tell the manager to carefully set the machine at the lowest setting and DO NOT inject any cleaners whatsoever! I have done the "drop the Pan" but, you just don't get all of the Fluid out as most of the dirty fluid stays in the Torque Converter and other areas that do not get at the bottom.
My Driving habits are pretty much like an Old Lady....not in a hurry to get going and if I see a RED Light up ahead, I just let go of the accelerator and allow the Camry to coast all the way to the line! If anyone is in a hurry to reach the RED light they can go around me.>:D I try to avoid high speed U-Turns to save on the CV assemblies and take em very slow or I just avoid them if I can do several RIGHT turns instead and venture to see the nice area that I am in and enjoy the scenery!0:)
I have replaced the entire rear suspension by purchasing a Kits such as:
http://www.ebay.com/itm/160971665484?item=160971665484&viewitem=&sspagename=ADME:L:OC:US:3160&vxp=mtr
http://www.ebay.com/itm/181076736459?item=181076736459&viewitem=&sspagename=ADME:L:OC:US:3160&vxp=mtr
http://www.ebay.com/itm/181076745221?item=181076745221&viewitem=&sspagename=ADME:L:OC:US:3160&vxp=mtr
You can read all about it at:
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/338662-what-did-you-do-your-camry-today-306.html#post7180585
and now my Camry goes down the road super quiet and firm like new.:grin:
Oh, Cooling System is very important in Central Florida as temperatures / Humid conditions can and will KILL any vehicle that doesn't have a sound Cooling System and as an example here is a recent Radiator Change out on my 5th Radiator for my Camry:
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/338662-what-did-you-do-your-camry-today-307.html#post7471522
Another big tip is to maintain a clean Engine and change out the Engine Valve Cover Gasket and use premium spark plugs such as NGK brand and don't forget the PVC valve and use a new rubber grommet!:wink:
More:
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/338662-what-did-you-do-your-camry-today-251.html#post4015682
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/338662-what-did-you-do-your-camry-today-251.html#post4012198
Timing Belt / Water Pump / Seals / etc.....:
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/338662-what-did-you-do-your-camry-today-253.html#post4033060
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/338662-what-did-you-do-your-camry-today-253.html#post4033581
Engine Timing:
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/338662-what-did-you-do-your-camry-today-273.html#post4847105
I hope that I have answered your questions.:nerd:
ToyotaRIMD
Camry 1999,
Discussion Starter #14 (Edited)
guapoman2000
Thanks for your success story details. I liked your approach.
I faceed the situation as above. As you have been there, I need your insight. I posted another related to camry 1999 (Timing belt jump/break situation), Here the url
http://www.toyotanation.com/forum/10...placement.html
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/967097-does-timing-jump-cause-engine-replacement-2.html#post8370802
Do you mind sharing your input/guidance, where to go from here?
Thanks for helping.
92 Toyota Camry XLE
guapoman2000
Thanks for helping.
Please consider this my reply to you:
http://www.toyotanation.com/forum/103-3rd-4th-generation-1992-1996-1997-2001/967097-does-timing-jump-cause-engine-replacement-3.html#post8378273
399,035+and going strong
"When do you use N when using an automatic transmission?"
If my engine was to stall while I was driving, I would put the transmission in N and try to restart it.
Reactions: ToyotaRIMD
9
Guest
Usually use it when stuck in traffic. Set the e brake and put it in N, then drop it back in D when traffic gets moving again. You can go back and forth between N and D without pushing the shift lever button.
ToyotaRIMD
Camry 1999,
Discussion Starter #19
Will it work if it happen on uphill driving?
What will you do differently on uphill driving/engine stall?
I guess it would depend on traffic situation, how much speed I had, if I could pull over and stop.
1 - 20 of 54 Posts
