A tried and true method for testing a shock it to place your weight on a corner of the vehicle and then let it back up. If it bounces up and down more than once, you have a weak shock. Leaking oil on the side of the shock is another signal. Also, how is the body lean on fast cornering?
An old style method for testing the exhaust system. With the car running, take a plumbers plunger and press it fully against your tail pipe. If the exhaust gas pushes the plunger back, your exhaust system is okay. If not, you have a leak someplace and a visual inspection may be in order.
Good luck.
Good luck.
