Where can i get stock springs?
2624 Views 44 Replies 8 Participants Last post by  yamahadave
Guys I am needing a set of new stock rear leaf springs. Know where I can get em from for fairly cheap? They are for a 95 4x4
1 - 20 of 45 Posts
did you check jc whitney? i think i need new what do you think?
-dave
jc whitney has them for around $160 or so each.
would helper springs take away that sag?
-dave
I am thinking about getting some Pro comp add a leafs to see if it will get rid of the sag.
Haha hey yamahadave thats exactly what mine looks like :)
I was gonna mention you're saggy ass but I tought it would be gay!
Helper springs have helped mine so far. They've been on there about 8 mos. Still hunting for a set of springs though. If you can swing it just buy them. I have a daughter in college so I can't afford to pay attention!
Haha yea could be construed as a little gay :) haha. Ok well I might as well just find some 5" lift springs huh. Or maybe some 4" and get some shackles. Thanks for letting me know my ass is saggy :lol:
yeah... DIAPER BUTT!
did you find them online?
-dave
Yea I found some online but I am not sure if I want to get add a leafs or lift springs
i was looking at mine today after i instaled my new deck and it leans alittle hard to the left(driverside)
-dave
at JC there about 150 still thats kind of steep. im going to call around tomarrow.
-dave
Let me know what ya find bro :)
what are the pros and cons of the add leafs? are they not as good as just replacing them??
-dave
Im not really sure to be honest with ya. Maybe a suspension guru will chime in :) I would like to know that myself
if its ok to just upgrade it will be alot cheeper.
-dave
Yea since I have a lift already I may go ahead and do the 4" new leaf packs with a 1" lift shackle
http://www.4x4wire.com/jeep/tech/susp/xj_aal_01/
here is some info but for jeeps.
" OME Add-a-Leafs
Add-a-leafs have a poor reputation and it's partly deserved. A really cheap path to a quick lift is to insert an AAL into an existing stock spring pack. This works at first, but is doomed to fail quickly. That single spring has got to provide all the vehicle lift plus it has to counter the forces of the tired stock springs. No way. Sooner or later the lift will be gone, and the money wasted.
My original spring packs, OME #JC1B, were too low and too soft when the XJ was fully loaded. The stiffer, taller #JC2A leaf pack could be what I really need, but instead of buying an entire new leaf pack, RRO suggested adding either an OME add-a-leaf, or a lift block, or both. The OME JCXL is an AAL designed to compliment my existing pack, not fight it. Von and I knew that the JCXL would add extra spring rate... about 20% more. That extra resistance to droop would provide part of my solution.
Ultimate Lift Blocks"
-dave
1 - 20 of 45 Posts
