Recently got a 09 camry and i was looking to install a system, where did you guys run your power wire? im not really looking to drill a hole in the firewall like in my old camry. thanks for any help.
Did you run the wire through it or next to it? The rubber protects the wire from rubbing the metal so that the insulation doesn't wear away and cause a short.I popped the rubber grommet off and after running the wire through, I popped it back in. Simple.
+1Use a wire, usually 10 gauge, and tap into the fuse block. This piece is called a fuse tap and any auto parts store has them. The fuse tap gets shoved into some secondary power fuse on the fuse block and pick it whether you want power on all the time or not. The owners manual has this information, if yours is absent just dl it. I have done this in the past and always spliced in a fuse of the appropriate amperage in the wire for a safety.
I dont like crawling around under the dash and to me this is the easiest and best way.
I like the idea and I agree that it's a lot easier than climbing into the engine bay and going thru the firewall. But this guy is planning on running a 0 gauge wire. Sounds like he's planning something big. Would power from the fuse box be enough to drive a 10,000 watt "monster" system? (hypothetically)Use a wire, usually 10 gauge, and tap into the fuse block. This piece is called a fuse tap and any auto parts store has them. The fuse tap gets shoved into some secondary power fuse on the fuse block and pick it whether you want power on all the time or not. The owners manual has this information, if yours is absent just dl it. I have done this in the past and always spliced in a fuse of the appropriate amperage in the wire for a safety.
BTW, BlackCam09, what are you planning for your system?
jeez nothing has changed, been a few days since i been here, clicked a thread, first thing i see is this comment..................... fail......Search.......................
lol that guy thinks the world revolves around him, and he thinks he knows it all. the njerald or whatever.jeez nothing has changed, been a few days since i been here, clicked a thread, first thing i see is this comment..................... fail......
E-A shit is good, nice price on that h/o alt. I need one for my gen5, but I'm just scared for some reason that it'll mess up something in my car.. :Bruce:I just ran it through the grommet and ran it under the door sill thing and it looks like fine like there's no wire under it at all. yeah in my old camry i was running the same setup im going to put in the new camry. I had a 160 H/O alt i bought off ebay and it worked great. I saw a h/o alt on ebay for the gen5. Yeah i also did the big 3 in my old car but in this car im installing anything until the h/o alt is installed first. I'm getting it custom built from excessive amperage for about 375 shipped he quoted me.
