Yes they are quite easy to install and find. if you find your air box look further past that it should be right there. It has a bolt, i believe it's 17 mm, if im not mistaken. there is two bolts you need to take off of the filter lines itself, top and bottom. And on the side on the tire well, if you want to take the filter off. One things you should make sure that you do is place some kinda of drip pan, because you will have gas leak out of it. but on e thing you have to look for before you start is the gas shutoff valve. It should be some where located on the head. It's a small screw possibly inside a cap (as mine was) But take the top and bottom and side bolts off and the filter should come off. it's kinda self explanatory putting it back on. Hope this helps!
