The fuse is located in front (towards the nose) of the drivers side strut tower in the main fuse box. It is the "EFI" fuse. There a diagnostic terminal block near the fuse block with a black lid. Open it and look in the lid and each connector is labeled. If you jumper "FP" to "+b" that will send +12vdc to the fuel pump.I don't have a diagram of the fuses and my fuel pump is not working on my 1990 Supra non-turbo. Where exactly is the fuse and relay? Also...What color are the wires to the fuel pump so i can jump it to see if it is working?
Thanks-Ken![]()
Should you actually need the relay however, it is on the upper right, the fuel pump resistor pack is on the bottom left.
I think me posting the wiring diagram is against forum rules, Bob (bgrieger) can clarify.
